Mystery Air Connect
Zadvark
North Carolina
Doing a rebuild on the Air Dryer (see to the far left) on my 923A1 and I spotted a tee that was installed with a quick disconnect. Not very convenient for practical use but reservists can be a wiley bunch :). Any thoughts as to their reasoning?
MtnSnow
14
NSL, UT
Reasoning?.........How about allows them to hook up a standard air hose that has the female portion of a quick disconnect without the use of a glad hand coupler.
m1010plowboy
2,627
Edmonton, Canada
We put them on trucks parked in the shop so they can be aired up and rolled outside quickly. The fire-trucks I've seen have their own hose that keep the tanks full all the time. Very handy.
Zadvark
North Carolina
I really do get that you can use it as take off air or keep the tanks full for a quick deployment. It's just in a pretty inaccessible place up in the frame rail on the inside. Thanks for the replies friends.
73m819
319
gainesville, ga.
That was put there by someone so they could put air to the system WITHOUT the engine running noise when looking for air leaks.
Csm Davis
382
Hattiesburg, Mississippi
What I want to know is what that other part is it looks like a vent off of an axle. uploadfromtaptalk1458751859088.jpg
MyothersanM1
19K M1 Armor Crewman
418
68
Culver City, CA
Why not use the emergency gladhand on the front or rear? I've aired up via the front gladhand without running the engine. Seems simpler that adding more fittings and additional plumbing.
porky69
Coaldale, Alberta, Canada
Looks like a Schrader valve to me. Use a tire chuck if you don't have the right quick coupler. Same could be said about not using the front glad hand, only works if you have a matching glad hand, this gives you two more options.
Castle Bravo
Hundredaire Socialite
223
Arizona
Other than that it looks like the pop off valve to me, another reason I say that is because that is what normally in that position on the truck in that tee.
Scar59
41
Mt. Eden, KY
Zadvark.
Clear this up, crawl under there and remove the cap to that Schrader and take another picture. Neat little mod if you have the time.
