Name that cargo cover!
Awesomeness
1,523
Orlando, FL
I bought a cargo cover that was supposed to be for my LMTV, but this clearly isn't. I want to sell it off, but don't know what it's for. Do you?
simp5782
Feo, Fuerte y Formal
9,511
Mason, TN
More than likely its for a deuce. Should have an Nsn painted somewhere on it to identify the vehicle. Or the nsn on the crate.
Awesomeness
1,523
Orlando, FL
There are no markings or NSN numbers anywhere on it, as far as I could find. As you can see from the pictures of it draped over the LMTV bed, it's for a vehicle that is either not quite as tall, or slightly narrower, as the sides can't reach down far enough on an LMTV.
The zip open window in the front, as well as the two "drier vents" in the upper corners, are fairly distinctive.
FloridaAKM
395
Gainesville, Florida
It is for a M35 Deuce, I bought 4 of them in crates with all the bows, staves & bolts for outfitting a Deuce. After installing a couple, you get familiar with them. I do have a M1082 that I put a tan 5 ton cover on that I scored for $20.00 NIB that was too short for the sides & too long in length, but works for what I want in static situation.
Ask $350.00 for it if it is in excellent shape or best offer if not. An entire tan crate of the system will run $600.00 or higher.
