Whitfield
- 5
- 18
- Richmond Virginia
![](http://www.steelsoldiers.com/attachments/cucv/215203d1237736860-doghead-starter-relay-modifcation-starterrelaywiring.jpg)
I am missing the two GREY relays beside the doghead mod (starter relay).
I've been chasing TM's / harness schematics for 1.5hrs = no joy.
Also of concern is one of them runs wires up to what looks like an exposed resistor (may be labeled Anode / cathode on schematic). I'm concerned that this is just floating with exposed leads behind the dash.
Almost found the answer here...
[FONT="]CUCVs have an extra starter relay under the dash. It is known to either rust and not work making the truck not start or to stick in the on position letting the starter run until the wiring harness or the starter itself burns up and is permanently damaged. [/FONT]
[FONT="]-The relay is mounted to the plate that the big plug is mounted to under the edge of the dash next to the 4WD lever. It is the bigger silver relay next to two black relays. Its purpose is to switch the 12v single from the ignition switch to 24v to trigger the 24volt starter. It has four wires plugged into it, The red wire is 24 volt feed. Solid purple goes to the starter. Black is ground. Purple with white stripe is the ignition feed. You can unplug these and jump the red to the purple and start the truck in an emergency. [/FONT]
