Nartron Directional Signal Control (Service/Not Working)
Runaway998
Richmond,VA
I have a Nartron turn signal switch. I plugged it and it worked for a minute and then stopped. It seemed delayed. Then it stopped working. I took it apart. Cleaned the contacts. Tested the unit with my volt meter. Everything looked right. Plugged it back into the truck and worked for one blink of a turn signal and stopped.
Is there any other service I can do to it?
Bulldogger
585
Quantico VA
LED or Incandescent bulbs? You haven't given a lot of information, but when I see one blink and then nothing, it's usually when an Incandescent flasher relay interacts with the very-low power draw of LEDs and refuses to blink properly.
BDGR
Runaway998
Richmond,VA
BDGR
I tried both LED and Incandescent bulbs in the unit. I have an older style turn signal that works without an issue. The truck has Incandescent all around the outside but I have all new lights and new flasher module. I just havent installed them yet.
Bulldogger
585
Quantico VA
Understood. Unless someone else has a different experience than mine, I'd say it's toast. It's not possible to open them up (all that I've seen) for service.
Bulldogger
