Nato J and B pins reversed
mikey
39
Lake Como, PA
I have an M931A2 from Red River with the J and B pins reversed on the female NATO plug at the rear of the truck. Because of that, every military trailer I connect to my truck has the turn signals reversed.
I looked at the rear of the plug and tried to remove the J pin with a little bit of pressure, but it didn't budge. I don't want to break anything. What is the process to remove the pins? Just a steady supply of pressure?
Mikey
73m819
319
gainesville, ga.
Just cut the two wires and resplice for the correct connection, you are making way to much out of this.
gimpyrobb
dumpsterlandingfromorbit!
27,785
749
Cincy Ohio
If you press out the rubber part inside the plug, you can then push out the pins individually. Its not that hard or complicated(as some might think).
KsM715
142
St George Ks
With disassembly the pins can be swapped but like 73 said just splicing could be easier. Just for fun I would try tracing out the harness and see if someone made it up wrong at some other point in the harness.
