- 10,350
- 94
- 48
- Meadows of Dan, Virginia
In the CUCV the batteries are not normally charged in series, my post above generally only applies if the batteries are normally charged in series (the deuce).
The problem with the 24-volt charger is that the two batteries will not receive the same charge. If the internal resistances are different (which they most likely are) a given current passing through both batteries in series will produce different voltages across them.
It's getting late, I hope it makes some sense.
