- 8,697
- 3,197
- 113
- Monrovia, Ca.
The difference between gen set, pumps, industrial, pistons, turbo and exhaust manifold and pump/gears and head. If the stationary engine has an MW pump, gtg, just install your stuff when you do the re block. If it is later, and yes Virginia, late blocks are backwards compatible, it will most likely use a P pump, so, you will need to change the gear and housing to make your MW work. You will most lkely need to swap flywheel housings, they are dowelled, so no dialing in needed. If you use an industrial head on an automotive engine, you will have un curable smoke due to different swirl factors made into the head casting. Liners and crank will be the same so you can leave them in and just do down the middle stuff. Just re ring the pistons. Just a word of caution, BE CAREFUL when pushing pistons out, if you break the piston cooling nozzles, you will need to remove the crank and, if you roll main bearings into the engine, the piston cooling nozzles can drop down and make it so the main bearing shell will not roll in, again, possibly requiring the crank to be pulled if you can't pull the nozzle up.
