- 157
- 0
- 0
- Washington, IA
I'm chasing down fuel issues with my deuce as noted in the attached thread. However, I thought I'd devote a short thread specifically to the Parker pump in case someone in the future wanted to search just for that.
http://www.steelsoldiers.com/showthread.php?107679-Deuce-cranks-but-no-start-ITP-source
I got my Parker in-tank fuel pump from Kipman yesterday. My issue is, I don't know how to properly power it. It has a plug on it with a wire that has been snipped and a ground wire. My old pump has a shielded power wire and a frame ground. According to the TM's, the old style pump was replaced from the fuse linkage on down and the wire was part of the replacement. I suspect that the shielding is a grounding method. Should I use the old wire, splice into the new one, heat shrink wrap it and connect the old shielding to another ground? Does standard heat shrink work in fuel without deteriorating and keep it from shorting out throught the fuel? Thanks. I'll post pictures this afternoon.
