So far nothing but showing blinking lightsopcorn: What does it do?
I just bought the TM 9-4120-411-14 through barnes and nobleYou have the manuals for it?
Yes, sir there is a remote I tried both ways. It doesn't go into 'fail safe mode' so I guess it's something simple.Did a rempte come with the unit? If so, try it. Or if you are using the remote, try it without it.
yes sir ... on both. The wire to the FDECU has bare ends so I connected them to the connectors .When you hooked it up, did you hook it up in a 3 phase hookup? Is your gen set turned to 3 phase, 208/230 volt output?
