need advice with FDECU 5
Lmtv772
Banned
651
19
Florida
LMTV,
I have been answering your PM's, but have the feeling they are not getting to you. When I look at my sent messages, they are not listed there. Have you had any answers to the last two PM's you sent?
no didn't get a response, Guy
Maybe I need to delete some messages?
~michael
Guyfang
26,892
Burgkunstadt, Germany
There has got to be something in the TM that specifies minimum requirements to run the Reefer. How about the HR section? Oh, what did the meters read for load on your 100 KW?
Lmtv772
Banned
651
19
Florida
I wish I could tell. The gauge doesn' work :(
it was 80 deg out today and the AC put out 55 deg
Poccur
146
Roanoke, VA
Pretty sure the manual says you need a 60 amp power cord...not that it will need 60 amps in general...now you may get a spike when the compressor fires but it will be momentary...
Unless you have a super high-speed amp meter it will likely miss a spike but you should be able to measure the running current and we can work it out...
FDECU had an EER of 4.8 so your power draw will be 10kW approx...expect current to run at 28 amps or so...
