Need Another Flexplate
cucvcan
Caledonia/On
Did you notice any damaged teeth on the flexplate or starter? I'd look for cracks in the FP. I assume you checked all the other bolts. But once the flexplate starts to wobble it gets progressively louder. I ended up replacing my 6.2 due to the problems with the crank end. I also put on a new torque converter. Just started running it again this weekend so it is too early to see if my problems are over.
I'd take another good look at your fp. If its still making noise I'll bet you've got a hairline crack. DO not operate your truck with a damaged flex plate or you could ruin the end of your crank too. Good luck.
beanman1
in the south
i check the bolts on the torque converter 1 was a lil loose tightened them up and still the same noise dont have the time to check the flexplate yet but the truck is parked at my friends house now i guess time to call a ride lol
