Need axle boot for front for MTVR
MAdams
125
San Dimas, CA
Pay special attention to what Eli said about the moly grease. Moly and normal grease doesn't mix well and moly can be hard to find locally
Sent from my SM-G975U using Tapatalk
IMP
12
Fruitland Idaho
Thank you
if no moley is available can we use a good quality grease ?
Elijah95
Certified Rookie
1,239
1,183
Georgia
Thank you
You will experience rapid wear of the cv joint itself.
You can order “CV joint grease” cheaply online by the bag; local places such as Walmart and tractor supply will carry it on the shelf or can order it
  • Like
Reactions: IMP
ehinlein
Pelham,MA
I've posted on this a while back. Does anyone know of any sources at a somewhat decent price? How many of us need one or two? I spoke with Con-Vel Inc , they no longer deal with them. Got one "Part Target" quote $260 each quantity 4, $500 ea. quantity 1! Another from WB parts $350 ea quanity 6! I guess $250 is ok if you consider it's a required part. Just because it's a rubber bellows doesn't make it automatically cheap and if there's no "surplus" out there...
GKN 10233206, Oshkosh 6HB995, NSN 2520 01 474 5708
I just need one.
luckypjs20
Cleburne tx
I just need one.
I also need 2
IMP
12
Fruitland Idaho
I just need one.
IMP
12
Fruitland Idaho
Go to your local auto parts and get one for a Ford expedition or explorer Oreilly's 614-700 about $ 35.00They will have then in stock
ehinlein
Pelham,MA
Not sure that’ll work. Axle shaft is about 3-1/2” on Mtvr. Other end about 7”.
luckypjs20
Cleburne tx
They're coming soon. Brand new production boots, just don't have a date yet
I'll keep an eye on here and on the 7 ton page on fb I still have a torn one I need to replace I had thought about reaching our to some of the big name off road axle manufacturers and seeing what it would cost to have them made
