Bows and Bending and Breaking
Had some success with Bow building so before we destroy these, thought I'd share the pics. M135 Bows are between 68 1/2" and 70" long. We chose 68 1/2".
I'll have enough bows for all three M135's real soon, just not sure how long they'll last.
We did a non-destructive strength comparison with an original Oak bow and Oak bows are strong. Mattech said guys would crawl between the bows for a nap so I need you boys on a diet! We're going to let a vet try and break one so pics and vid soon.
Using the 1/4" Birch Plywood and pins/ bolts/ spikes on a 7' long wood counter works good. A metal press would be better, but this works. One SS thread showed a guy using his deck for a jig surface and we could also use a 2x8 since the arch is only 5 or 6 inches. We chose 5" because it roughly matched an nice NOS piece.
![P6170652.jpg P6170652.jpg](https://www.steelsoldiers.com/data/attachments/469/469416-228ec9799efe5dc9214ac6861578bd2c.jpg)
Now for the little successes. I did not choose these methods, they happened and it made things easier.
The bolts on the two ends of the jig were longer. It made it easier to slide the glue covered pieces into the jig.
![20170617_161119.jpg 20170617_161119.jpg](https://www.steelsoldiers.com/data/attachments/469/469419-60e50a490958df224567fb9415a0626a.jpg)
![20170617_153436.jpg 20170617_153436.jpg](https://www.steelsoldiers.com/data/attachments/469/469413-ae5a7533a1cd56b36cf5cc727ecfbdba.jpg)
![20170617_153209.jpg 20170617_153209.jpg](https://www.steelsoldiers.com/data/attachments/469/469412-3d779cb5045a470940a455c547d6ea46.jpg)
Found a piece of wood that was slightly narrower than the bow, maybe 1 3/4". When you make a stroke over your glue it leaves a nice thick row along the edge. A quick smear on each edge and you've got a nice thick layer for the outside edge and a healthy film down the middle. You need to work fast with this glue so this method worked farmyard fast.
I had our supplier cut 2 - 4x8 sheets in 2 1/2 inch strips so expecting them all perfect would have been a stretch. It is important to have them cut as close as possible to reduce sanding and prep time. Even this little difference in width takes extra time to finish.
Birch does finish up nicely. After 4-5 minutes to glue one together, 24 hours in clamps, it takes about an hour with a 60 grit belt sander and a 120 grit palm sander to get them smooth. Now we just need some help deciding to paint them or not.
![P6170658.jpg P6170658.jpg](https://www.steelsoldiers.com/data/attachments/469/469417-e2156a2c4b6ab830825af8161845e859.jpg)
![P6170659.jpg P6170659.jpg](https://www.steelsoldiers.com/data/attachments/469/469418-7d4844f44cd6af468a50691ddba17979.jpg)
