I purchased my M1009 about two and a half years ago. Brought it to my mechanic and asked him to get it in shape to make the drive from Santa Barbara, CA to my cabin near Idaho City, ID. Made the drive without a hitch and it has been up in Idaho ever since. Only maintenance done since then was an oil change. I do not remember or have paperwork on what my mechanic did when I purchased it. It only gets driven for about a month a year and maybe 200 or 300 miles. I do have someone go over and run it four about a half hour every two weeks and it is parked inside a heated garage.
I am going to ID in about a month and will be there for about two weeks without the wife, so I decided that would be a good time to work on the CUCV. Here is my plan, please let me know if I have any of the fluids or parts wrong.
Mobil Delvac 1300 15W-40 (8 Quarts)
Mobil 1 Synthetic ATF Fluid (Transmission and T-Case) (9 Quarts)
Lucas Synthetic 75W-90 Gear Oil (Differentials) (5 Quarts)
Prestone Black Cap (Green) (Three Gallons) Coolant
Mobil 1 Synthetic ATF Fluid (Power Steering)
K&N HP-3002 or Mobil 1 M1-302 Oil Filter
Any DOT 5 Brake Fluid
Mobil 1 Synthetic Grease
Thermostat – NAPA THM-381190 & THM-1040ST Gasket or FPG-35271
I am also wanting to change the transmission filter, fuel filter, all glow plugs, air filter, belts and the injectors plus return lines. When i do the coolant, I am going to flush with Irontite thoro flush and then add the all weather seal.
I just did this same service to my H1 and was very happy with the results. I know that not everything on the list may be 100% necessary, but I like having a good baseline on knowing what is what and what has been done. I figure I have the time to do it and the cost should not be to bad, so what the hell.
Can someone help me out with part numbers and good sources for the glow plugs, transmission filter, fuel filter, air filter (paper), belts and injectors?
My M1009 is a '87 that has a 4" all spring lift with 35" MT Baja Claws. Black powdercoated the stock wheels. Installed aftermarket racing seats on custom built sliding bases. If I have time, I will have the muffler shop bend and weld up a full cage for the interior. Bare floors with no coverings, ZERO rust and no back seat.
TIA guys.
TIA guys.
