ryanruck
- 45
- 28
- Cincinnati, OH
Been a lurker for a while reading but now I need some information so, I hope I'm posting this in the correct location.
I recently picked up what was described as an MRAP interior LED lighting kit, listed as:
P/N MRP22360
LRIP 9 Interior LED Lighting
System Retrofit Kit
NSN 2590-01-579-4922
Modification Kit, Vehicular Equip
I believe it's BAE manufacture, from what I've found, and has 6 Grote White/Blue dome lights similar to the 82400 (mine has 4 white, 4 blue) with associated harnesses and hardware.
My problem is that it only came with a packing list, no installation instructions like every other military parts kit/upgrade kit I've bought. Each of the parts are labeled consistent with an instruction sheet that isn't there.
Seller says he doesn't think the kits came with any instructions.
I've been working on toning out the leads on the harnesses trying to match everything up but it's getting tedious so I figured I'd check here to try and save some time and sanity.
Anyone have any installation instructions associated with this kit?
I suppose I could run power straight to each of the lights but I'd really prefer to use the existing harness since it would make for a cleaner install and that was a big reason for buying it.
Thanks!
P/N MRP22360
System Retrofit Kit
Thanks!
