panzerjunky
- 0
- 0
- san diego ca
Good gvening fellas
Let me start the tale
I am starting to get my trucks P.M. stuff on track I have had the truck aprox 2 1/2 months now.
I had to replace the oil pan due to a J.B. welded plug ( not acceptable) so i held on the oil change until I had the new pan, pan gaskets, filters ect. As well as fuel filters.
Ran the truck aprox 15 miles to warm up drained the oil all went fine changed the pan and oil filters all went fine.
Then came the fuel filters I suspected that i would have issues due to the fact that the drain cocks would let nothing through pulled both the final and secondary filters I was supprised any fuel got through they were comopletly coverd in sldge the secondary a lot more so than the final in fact the final just had a bit of build up in the bottom of the filter housing and a little on the element. The secondary had about an inch of crap in the bottom of the housing cleaned them all out cleared the cocks and changed out those 2 filters without a hitch.
Pulled the primary filter it wasnt to bad ( I am suspecting that it was changed by the guy I bought it from) changed it out bolted down the alt. no problem.
Opened the vent cock between the secondary and the final filters hit the aux switch low air buzzer came on all is good but........after 5min no fuel at the upper vent shut off the vent cock between the filters opened the cock on the primary nothing no fuel nothing. pulled the fuel line feeding the primary filter header hit my aux switch no fuel pulled the line on top of the fuel pump no fuel pulled out the fuel pump kept the power to it hit the aux switch nothing no wirring no pumping nothing.
What happened.... it ran like a champ 5 hours before now nothing I primed the pump no go checked for power to the pump at the plug as the plug faces you there are 3 holes the top locator right and left I showed power on the right I am assumeing the left is ground.
Did my pump just coincidentaly crap out?????
The issue being cash is tight this month (customers are haveing issues paying on time) and i have a bit*# neighbor who already told me if it is there 3 days she will call the cops and have it towed.
Does anyone have one laying around they can part with on a credit type situation till I have a couple customers pay me ( end of this week early next)
Any information , advise, help ect would be apriciated.
Thanks Jerry
Thanks Jerry
