Need help 003a in previously perfect condition stopped producing power.
storeman
52
Mathews County, VA
Found the problem! My back has been bothering me so I apparently did not get low enough to see that I failed to reconnect J12 after I had moved it out of the way to cut the neutral to ground wire. All is well. Thanks for all your efforts in trying to help me. Good cheap birthday present!
Jerry :oops::oops:
dependable
190
Tisbury, Massachusetts
The neutral (LO) to ground wire is held on by nut (1/2 inch wrench I believe) on back side of ground terminal nut on frame. I unbolt it and tape it off, and make a note (on tape) that neutral /ground bond has been disconnected. That way unit can be put back to separately derived configuration by just re attaching the wire that connects LO to ground. Just saying you don't have to cut the wire.
Rapracing
Western Pennsylvania
Yep! That's what I did only I didn't put a note on it. Hopefully if I ever need it I'll remember where I took it off :mrgreen:
