Need help finding correct tie rod for M1009
478
13
Tucson AZ
The moog website part numbers for a suburban are good for the 10b in a m1009. You can contact customer support to verify part numbers. The moog parts might not be as nice as the ORD but they are definitely an upgrade from stock.
gweis12
frankfort, il
I'm replacing a bunch of the front end components on my Blazer rust wagon before I get a new set of rubber. Darn near every tie rod has excessive play in the joint and I want to alignment.
My problem is that I cant find the tie rod at my local parts stores. I referenced the TM and it comes back with a left and right tie rod end, the adjustment sleeve and a center adjusting tube. Mine has a one-piece drivers side rod end that runs all the way to the adjustment sleeve on the passenger side. I can't seem to find this part anywhere! I feel like I'm missing something or maybe I'm just losing it altogether aua
Anybody have any tips?
gweis12
frankfort, il
Tom, I have a CUCV-M 1009. I went to replace the tie rod end...it will not come out. I put a torch to it...nothing. It will not come out. I went to the Chevy Dealer. GM no longer makes the part. Can you recommend a place that sells that 5 foot tie-rod. Thanks, Gary
