Need help identifying this rim
juanprado
2,786
Metairie/La (N'awlins)
I think it looks like the one I have off a MRAP RG33L
Check my classified listing: (deleted add due to wrong id)
Do yours have the same numbers stamped on it?
I had removed the CTIS valve and tubing to disassemble it. It is not in my pics but the set up is identical to your pics.
Mine had a 16x20 tire mounted on it.
1,170
Post the picture, not a link.
cerial0411
Middleville/MI
It is on a auction site and they only have the one for sale. I have requested stamping numbers with no response from the seller.
There is no point in buying just one rim to find out it is something I will have a heck of time finding the other four.
That is it juanprado. If you happen to have another 4 laying around I am interested. I just don’t want to get in the one rim situation I am trying to avoid.
When trying to upload the picture I get a:
500[IOErrorEvent type= “ioError” bubbles= false cancelable=false eventPhase=2text= “Error #2038“]
Which is a generic flash related error between my server and the site. I have updated/used previous versions of flash, disabled my firewall and so on. I have tried jpeg, gif, and jpg format at low kb. The error only happens with this site.
I have been trying to post the picture for nine days then just gave up and posted the link.
Now, that I know what the rim is I can start searching five rims using the proper information.
Thank you for all your help.
juanprado
2,786
No, I only have one. I got if from GL at Ft. Polk very reasonable :)
There have been 3 or 4 more released since then at Ft. Polk one at a time but they went way higher than what I thought they were worth.
There are a bunch of steel wheels available. Can't tell what they are from and I did not spend any time researching. Check your pm for link.
I am clueless on the computer speak but posted the pic for you.rimoffset_zps3c8d2ff6.jpg
juanprado
2,786
After getting feedback from many of you, I did find and search the numbers stamped on the rim I have and it is spot on for a M1070. "Surprise" GL description was wrong. :)
Numbers stamped on rim:
MFR 20076
45152
1917010
Corresponds perfectly to NSN 2530-01-355-0639, Oshkosh mfr 45152, Part #1917010
http://www.parttarget.com/2530-01-35...chtext=1917010
I have updated my listing.
Cerial0411, looks like it was a M1070 after all.
