need help - mx 6707 w/ as 1729 on m1009
donalloy1
Martinez Ca
have mx 6707 matching unit w/ as 1729 mounted on M1009. looks extreme! will keep down tied down for over road. rather not take out low flying aircraft. trying to keep cosmetically original. hopefully doing good so far.
i would like to bring in am/fm signal on this combination. how do i accomplish that? want to bring signal into current off shelf radio. PLEASE HELP... :shock:
combat jump
Raleigh, NC
Antenna length is not critical for a radio that receives only. Transmitting is different - The antenna must be resonant on the transmitting frequency or power sent it from the transmitter will be reflected back to the transmitter. This reflected power becomes heat in the final power amplifier of the radio. At best, only a small fraction of transmitter power leaves the antenna. At worst, the power reflected back into the transmitter causes damage.
