murfsmog
- 1
- 3
- Traverse City, Michigan
Please can anyone help?
I have searched high and low at case dealers and aftermarket parts dealers. No luck.
I’m 100% sure this powershift (transmission control) module is bad and will not let the back hoe loader move forward or backward. I tested it with a module from an identical machine.
Where can this be fixed or replaced? It was water Damaged thanks to the hole in the military cab right above the steering wheel and module.
Case CNH part number 87589496
Case shows it backordered for well over 3 years.
Attached are some photos of the board and the backhoe loader.
Thank you.
Thank you.
