Need HELP please transmission control module for 2008 Case Backhoe loader 580 SMii (industrial BHL backhoe loader)
murfsmog
Traverse City, Michigan
Please can anyone help?
I have searched high and low at case dealers and aftermarket parts dealers. No luck.
I’m 100% sure this powershift (transmission control) module is bad and will not let the back hoe loader move forward or backward. I tested it with a module from an identical machine.
Where can this be fixed or replaced? It was water Damaged thanks to the hole in the military cab right above the steering wheel and module.
Case CNH part number 87589496
Case shows it backordered for well over 3 years.
Attached are some photos of the board and the backhoe loader.
Thank you.
NDT
6,990
Camp Wood/LC, TX
Yeah Case has left me high and dry on machines as well. Is this board mil specific? If not, do any machine dismantlers show to have it? Are there any 3rd party repair facilities available for this? There is a shop that fixes Allison boards. Did you try any tricks to fix your board, like cleaning it and the contacts?
2,943
Since the ho is a milsurp thing, maybe try some of the vehicle dealers like Memphis Equip, White Owl, Eastern Surplus and the likes. Try contacting C&C equipment, they might have pieces parts or know where to send the TCM for repair.
@murfsmog, are you Domorguy over on heavy equip forums? That guys stuff has been broken +10 years!
