- 410
- 33
- 28
- Atlanta, Ga
Having problems with a military 361 V8. Engine was rebuilt about 10 years ago and was never started and the previous owner put a little marvel mystery oil in the cylinders every few months and turned it over. The carb currently does not have gas going to it. only trying to get it to fire with starting fuild to make sure it's good to go before I put gas to the carb. Original carb is switched out to holley 4 barrel 650 cfm with edelbrock 383 performer intake manifold. My issue is that I can't get it to start, even using starter fluid. No sputter, no hits, just nothing.
Here is what I've done:
1. Confirmed timing and made sure that is was not 180 degrees out.
Used bore-scope to watch valves open and close by bumping the engine, once intake valve closed, let it come to TDC then aligned the timing mark with the 10 mark. Turned engine over and check with timing light and adjusted distributer.
2. Checked and set both points. Cleaned points and then set them to I believe 17 or 18 gap (what ever the manual called for). (why are their two sets of points? Just curious if two are actually needed and why, can I remove one?)
3. Put new plugs and gapped them to .030.
4. Checked compression and each ranges from 120-130 after 4-5 seconds of turning over.
5. Checked to make sure each plug was firing (spark).
Using remote starter switch (with ignition and master switch turned on) tried to start engine and nothing.
Sprayed a little fuild into the air horn then using remote starter switch started trying to crank. There was a little puff every 3 to 4 seconds then a big bang in the passenger side mufflers about 7 or so seconds into the process, this happened a few times from the starter fluid fumes building up in the exhaust and then being ignited. That is about the only life I can get from the engine.
WHAT THE F*** can be the problem with this engine? Weak coil? internal timing off (if that was the case then I think that there would be serious compression issues plus #1 seems timed right. I'm about at my wit's end and almost ready to yank the engine even though it's a huge huge pain in the ass, esp since I'd have to get a gantry crane to do so. PLEASE HELP!
Thanks
Jason
Thanks
Jason
