Need help with diagnostic on this generator in Indianapolis. Any help would be appreciated & compensated.
Chainbreaker
2,112
Oregon
Unfortunately your photo does not show the complete MFG's data plate at top of photo. What is the MEP-XXX model?
Are you looking for onsite help, online help or both?
What is history of genset...new to you?, running or not running?, has it ever provided proper AC output?
CFlooring77
Indianapolis
Does this help? It runs well. Engine is solid. We acquired it last year. Something is wrong with the fuel shut off I think. We had a guy working on it that couldn’t figure out the computer control. Onsite or other would be helpful. It’s a clean unit.
Guyfang
27,325
Burgkunstadt, Germany
1. So whats the problem?
2. Have you downloaded the TM's from the forum here, for this set? Maybe looked at the operators TM?
3. Have you ever seen this gen set work right? Or is it new to you.
4. Do you have tools and a multimeter? And know how to use it?
Chainbreaker
2,112
Oregon
If you hit "Click to Expand" where he replied just below my message he explains what he thinks is wrong. Note - Looks like he accidentally replied above the [/QUOTE] end mark and his reply got appended within my message and you can't see it unless expanded.
155mm
Chief and Indian
506
Guymon, OK
I copied and pasted reply so it is inline
“Unfortunately your photo does not show the complete MFG's data plate at top of photo. What is the MEP-XXX model?
Does this help? It runs well. Engine is solid. We acquired it last year. Something is wrong with the fuel shut off I think. We had a guy working on it that couldn’t figure out the computer control. Onsite or other would be helpful. It’s a clean unit”
155mm
Chief and Indian
506
Guymon, OK
Print off that pdf, and take to him. To troubleshoot the fuel actuator, also have him test the magnetic pickup before yall spend a bunch of time doing some other troubleshooting
