Need help with Multi-fuel Personnel Heater
coyotegray
10
Oklahoma City
Ok, I installed it new last year about this time.
Has run great. Very nice to have over the winter...
I had not started it (The Heater) over the summer.
I have been trying to sell my truck and today I had a guy who was going to come over and take a look. He couldn't make it but I started fooling around with the truck just to make sure everything was working correctly.
The first time I fired up the heater it belched out so much smoke I couldn't see anything. Tried again with the same results. So I started backing off the fuel adjustment. The smoke cleared. Stop and started it a few times and everything is great. Then I had it running and it "back fired" and shut its self off. I got a little flame out of the intake and then it came back on and went through the shutdown process. Now when I try to start it I can feel and hear a breaker in the control box flip.
Ahhh!!!!!!!! What the ****!! It had been working perfectly.
Any Ideas..?
Thanks,
Andy..
jwaller
19
Columbia, SC
what happened is you messed with a very finely tuned fuel adjustment and now you have no way of getting it back to the correct setting. it was smoking a lot because it was clearing itself out after not being used for months and months.
good luck with fixing it.
I guess you could play around with that setting but if your now hearing a breaker trip it sounds like the heater has internal wiring short, most likely due to the backfire cooking some wires, mostly due to the improper fuel setting.
coyotegray
10
Oklahoma City
What would it be clearing out? I let it run hoping the smoke would clear but it just went from white to black. I know where the setting was originally. When I turned it back up it would start smoking more.
What internal wiring could have been damaged?
What condition would cause a back fire in the first place?
