ke5eua
- 40
- 48
- Baton Rouge (Central), LA
I picked up a M1079 for a member and got it topped off with fluids. I flat towed it to the house, that was an adventure in itself. Last night I was going over it preparing for the road trip to bring it to it's owner in Louisiana and noticed the battery gauge was in the low yellow. Got out the vmm and verified it wasn't charging.
Now, went through the entire tm, and did the troubleshooting procedures and to verify past step 8 I need a known good regulator. Problem is I don't know if it's the regulator or the alternator. Anyone have a known good regulator I can use, or I can put this one on your truck to verify it's bad or good. I'm in Central Texas and will travel, although I'm sure the wife is tired of being in the car as we've traveled between Temple and College Station all week.
In the pics you will notice my Vaniar equalizer installed, I put it on it while I had the truck slaved to a wrecker so I could balance the batteries.
I would like to get on the road Monday, no later than Tuesday as I also have to make it to Alabama to pick up some trucks.
If there is anyway I can rule out the regulator manually please let me know.
To answer the basics:
Did you read the TM's? Yes, I even went as far to print out the 34 page schematic foldout and trace the wires.
Did you search the site? Yes, came up with one post about a frayed wire. Checked and it's not the case.
Regulator in question.
![20150508_201120.jpg 20150508_201120.jpg](https://www.steelsoldiers.com/data/attachments/380/380977-ca388e854c1bbf16fec7f029b319f9dd.jpg)
Current battery situation.
![20150508_105124.jpg 20150508_105124.jpg](https://www.steelsoldiers.com/data/attachments/380/380976-639a4ce8324d639dd650a92aefe9c412.jpg)
28v side output with engine running.
![20150508_105050.jpg 20150508_105050.jpg](https://www.steelsoldiers.com/data/attachments/380/380973-5ea8a5d9523208971fe86fb59e2d025d.jpg)
Individual battery voltages while engine running.
Left (Main +)
![20150508_105054.jpg 20150508_105054.jpg](https://www.steelsoldiers.com/data/attachments/380/380974-cd5f5f93144a466e7bbeafc92776a146.jpg)
Right (Main - [Also 12v side]) This is why I put the equalizer on when I was charging from the wrecker.
![20150508_105105.jpg 20150508_105105.jpg](https://www.steelsoldiers.com/data/attachments/380/380975-5926e4f3f732255032e990cd447bd75e.jpg)
Left (Main +)
