wiccantoy
- 0
- 0
- North wales , pa/ Williamstown nj
O whell guess not
Ok I have a tester.for compression for a car or truck not small engine. As far a primer I've done it before starting never during the starting process. This gen ran before I started to tune it up. This is why I'm sob confusedWell i dont know anything about that model but getting back to diesel basics, if the injectors have fuel and are firing then you need compression. If your compression is low it will never fire. Does the engine give white smoke when you crank it? If your using starting fluid and it still wont kick that tells me low compression.
