need hemtt Detroit Diesel 8v92ta mechanic near Sacramento
Ajax MD
1,435
Mayo, MD
My neighbors thought I was a badass for replacing my M813 transfer case. This is totally next-level stuff. Very educational to watch.
bigmike
364
Dixon CA.
Update 4/4/2020
I’ve had many a sleepless night about how to get the upper main bearings out. Today I fabricated a pusher tool out of a brass hose fitting. I went back and forth between the belt sander and the motor using a mirror to see my progress. I had to use a lite touch when testing the tool to push out the upper main just in case it got hung up between the crank and engine block. I am proud to say I successfully drove out my first upper bearing. Now I’m ready to begin the process of changing out the mains. Cross my fingers it will last thru all the bearing replacements without shearing.
bigmike
364
Dixon CA.
Looking for 11/16-11 X 1 1/2” long bolts for my liner hold down clamps. Qty=16. No luck at fastenal, grainger or McMaster Carr.
Tracer
14,288
Hawthorne, NV.
Mike, we have a True Value Hardware Store the next town over in Yerington. That's where I usually get my Grade 8, Stainless, Studs etc etc. Usually at Fastenal, if they don't have it in stock they'll order it. I've ordered some pretty odd bolts in the past that they didn't have in stock, and in 2 or 3 days there they are. I think they have a major warehouse in the Sacramento area. Good Luck with this.
Jbulach
2,391
Sunman Indiana
Probably have to have someone turn some bigger bolts down for you. I may have some 3/4” bolts with 1-1/2” or more of shoulder I could send you if it comes down to that.
bigmike
364
Dixon CA.
If it comes to that, I’ll make spacers to offset the head thickness .
bigmike
364
Dixon CA.
Update 4/6/2020:
My brass pusher worked great and 4 of 5 mains are changed. Could not get rear #5 by myself. Couldn’t reach the bearing with one arm and turn the crank with the other. I’ll solicit the help of soldier B “ the wife“ next weekend. I also made PVC spacers so no need to keep searching for the unicorn 11/16-11 bolts. I also assembled my spin-on oil adapter To replace the canister. Ordered a pair of piston ring pliers via amazon.
bigmike
364
Dixon CA.
Update 4/12/2020:
got the mains changed out. torquing to 240 ft/lbs was no easy task. One nice sized pieces of pipe to the rescue.F6DD24B5-4878-479A-9667-7F12548B3BDF.jpeg
assembled the new pistons. needed to find a creative way to hold the connecting rod and be able to torque to the proper spec.DF5C016C-B069-48BA-BDB1-96E143668278.jpeg6025F5EB-A74F-4F76-A547-A652B13B63CE.jpeg
started reassembling the heads.
bigmike
364
Dixon CA.
Good work. 240 ft.lbs. is a lot of twist! Do you have the special tool for the wrist pin seals, caps?
Not sure what you are talking about in regards to the special tool? I don‘t see it mentioned in the TM.
Valor
228
Apple Valley, Ca.
The service tool part number is a Kent-Moore tool part number. A mechanic told me to just use a golf ball but I havn't done that yet. It should work. Just make sure there is no leak at the wrist pin retainer or you will get lube oil leaking. How about the sleeve to install the pistons in the liners? Do you have that one? Maybe can just have a shop do it for you. Keep up the good work. I can't wait to hear the 8V92T sing!
bigmike
364
Dixon CA.
I used a socket just big enough to seat the wrist pin retainers. The TM did not specify a special tool to install or to use for leak tesing. They all went in good with the detent facing in. One was a bit problematic and it got buggered up just a bit At the edge. I ended up with an extra retainer so I may pull Out the buggered up one and replace. Will Wagner lent me a ring compressor for installing the pistons in the Liners. I’ll post a pic of the buggered one this weekend.
