Need part in nebraska, broke down out of town
Jon Giovani
omaha nebraska
Was recovering newly acquired m934s and the one my son in law was driving had a control arm come apart right in the middle of town he was able to get it off the road wondering if anybody in the area has any parts? I am in Beatrice Nebraska. Thanks in advance, Jon 402-651-1204
infidel got me
32
Newberry, Florida
We had one come loose last year while turning around in a parking lot. We pried it back on/in place and rachet strapped it together to get it home. If you don't have to far to go and drive sensibly you should make it. The next day we welded big washers to the outside of the dog bones and haven't had a problem since. These are a weak link on 5 tons. GOOD LUCK!
Scar59
41
Mt. Eden, KY
Jon,
Way to far to show up, Infidel's suggestion is the easiest fix. Get the dog bone back on the stud and strap it in place. Weld repair is the easiest fix. Big washer or bar stock.
Good luck
JC
Swamp Donkey
The Engineer
119
Gray, GA
Use wheel chocks in front of and behind the wheel that needs to line back up. The wheel chocks will keep the axle stationary while you move the truck forward or backwards to line it back up. Get the rod back on the stud and secure it as stated above. Try to make wide turns and take it slow. I know it's a little shocking when you first look under there but it's not that bad to field fix. I had the same thing happen a while back so I know what you're going through.
gimpyrobb
dumpsterlandingfromorbit!
27,785
747
Cincy Ohio
The easiest way we found to move the axle (if it needs to go forward) is to run a chain to the front tire then steer that tire to the other side. Bam you have hydraulics moving the axle for you.
Scar59
41
Mt. Eden, KY
Gimp.
Great idea, you need to publish a handbook with all your neat idea/fixes, "Gimp's Fixes".
