Need some electrical help
Mello
Austin, Texas
Ive searched long and hard trying to find info on this problem on here and across the net.
First up, I'm pretty good when it comes to electrical work, but i'm kinda stumped.
My 1028 has already been converted to 12v, single alternator, and all that stuff.
Alrighty, so, main issue, voltage rests at about 12v and will jump up to between 13-14v but come right back down. Second thing is I can smell something burning, no visual on that though, no smoke, nothing.
Now, the larger wire off the alternator to the 'thingamajig' on the passenger side firewall with several other wires going to it is the only wire I can find that hotter than the rest of them. I'm thinking either the alternator is shot, or the regulator is faulty and causing these issues. But, I dont want to go buying parts to chase down the problem and it be something simple. Any help/ insight would be greatly appreciated!!
Thanks,
Brad
Cucvnut
61
Carver, Oregon
The thingamajig on the firewall is the power bus. take the alternator to autozone and have them check it. did you bypass the regulator on the firewall for thr GP's ? Did you do the bypass on the GP relay ?
6x6TRex
Flint, MI
Of the 580,000 results from google on thingamajig, that still doesnt tell us exactly what it is. Take a picture of what your setup is on your truck so we can get a better idea of what we're working with.
If you want to replace an alternator that putting out 13-14V go ahead, I would worry about the regulator being bad when it starts reading 16-18V. You can take it and have it tested but 13-14V is the normal output of most standard alternators.
