I finally got the glow light, (and adjoining circuitry) to work properly. Went to start, and nothing. This tells me that the next step in getting the M1097R1 truck to start, is in fact the starter. After troubleshooting, I found that that my " I " (74A) wire from the engine side of the control box is not connected, to include a errant black wire on the top of the start, and my 74B that goes to the diagnostic port. I am asking if someone can take a picture of how their starter is wired or an explanation. I have my large schematic, but the images are in logic form, not true diagram. I have attached a couple of pictures. There is a gray terminal bus with three bolts that have nothing on it. The I wire has a red insulator on the terminal lug, The red wire in these pictures is my homemade grounding harness. After reading the manual 74a and b go to the same connector with a clip and I have no clip. Any help would be appreciated. Everything checks out so I truthfully believe that I am 15 minutes away from getting this girl started.
