Need the TM for doing dogbones
acesneights1
22
20
CT
I'm stuck in jury duty and need the torque specs etc . It's hard to surf them on a tablet. So far went through 6 threads here and 4 tm's and can't find it. Could someone with better acces just post the link to the appropriate TM?
I'm stuck here all day it looks like so it would make good reading as I have to do some tonight.
acesneights1
22
20
CT
This truck has a wing plow. It leans badly to pass side. I'm wondering should I jack it level before I install, install with the lean, or split the difference. It will always have the plow so if I install them jacked level it will be stressing them under normal operation....
thoughts ?
i'm thinking either with the lean or split the difference.
simp5782
Feo, Fuerte y Formal
9,368
Mason, TN
Level it out. I always tighten the nut by hand strength with the wrench then hammer tap it a few times till it gets harder till i get the cotter pin to line up.
Sent from my SM-G860P using Tapatalk
Lukes_deuce
124
Long Island, NY
When i did mine, I made sure everything was level. Dont want them to be stressed when sitting level. Also tighten them with hand tools. I heard of using an impact gun could cause them to spin in the actual dog bone. I do suggest 1 inch drive tools and lots of cheater extensions. I used my 1 inch big impact and had mixed results. I dont really have enough air to properly run it. I ended up grinding off a few of the nuts. Another good tool is a river buster, or small air jack hammer. Works great with a flat chisel in between the dog bone and axle boss. Heat is also your friend.
therooster2001
44
Colorado
Assuming the truck is a M939, torque is 350-400 lb
Once you get the cotter pins out, you're home free. I got two off in a salvage yard in 20 min flat, but couldn't do my own in 3 days and had a truck company do it VERY expensively. The TM is the Field Maintenance guide, #3, WP 0544. I have some extra pins if you need them.
Several good threads on castle nut removal and how to get the, off with wood and a wood splitter.
