Sarge29
- 1
- 18
- Saluda, SC
I finally have the 998 about ready to test drive. Before I put power on the truck again I would like to check the wiring for anything that may cause more problems. Last time I tried this I had a EESS box failure and had to replace all glow plugs and the EES box as well. I have used the ohm meter to check the body and engine harnesses for short and ground faults. I am getting a reading on the glow plug circuit, fuel stop solenoid, and the cold advance circuit on the engine harness. I get a dead short on the park brake circuit when the park brake is on, but this clears when the brake is off. Everything else checks clear on both harnesses. I think everything is OK from what I can tell by looking at the wiring schematic in the TM but want to be sure before I connect the batteries again. Is there anything that I am missing?
