Need transfer case help
DMF
Warren, MA
I have a transfer case from a 6x6 with split axles in my home-made skidder. The output shaft to the front axle is leaking. I removed the driveshaft and I need to buy a 1-1/2" socket to get the yoke off. Is that all I need to remove to get the seal out? There is a cover surrounding the seal with 4 bolts; does this need to be removed as well? Is there an exploded view/parts list available for this T-case? I looked in the TM forums but could not find any. Thanks in advance for your help!
NDT
7,502
Camp Wood/LC, TX
Yup remove the yoke and the retainer, replace seal with modern seal (take yoke and retainer to bearing supplier for measurements). Remove shims if there is shaft play. Put a speedysleeve on the yoke if it’s grooved.
  • Like
Reactions: DMF
DMF
Warren, MA
So the part with the 4 bolts needs to be removed as well then? Just trying to be clear. Thanks!
