Need Valve lash measurements HELP !
Eric's hifim37
Barstow, Ca.
Hello,
I have borrowed my buddy's mule ( for Tower Park ) and I need to adjust the noisy valves, can one of you please provide me the clearance for the intake & exhaust ? also I need to know if it is a HOT or Cold adjustment.
It is a 1968 M274-a5 Baifield w/ AO-42 2 cylinder engine
Thanks in advance !!!
Eric..
1,168
Isn't it on the top of the engine, on a data plate?
poof
Dirty Hippie
568
19
Wisconsin, Watertown
Might your Noisy lifter sound be the Magneto? it is loud sounding Klack..
Hydrolic lifters.. and the head i just installed was 100% drop on no adjustments on the rocker arm assy..torque to spec... ... check timeing...drive on..
Eric's hifim37
Barstow, Ca.
Thanks for the replies, I did pull the covers and it does have HYD lifters. The MAG is quiet so I guess we'll run it as is and see what gives someday, then overhaul time :sad:
Cheers, Eric..
