- 1,246
- 503
- 113
- Guymon, OK
You said the hz gauge only goes to 11 o’clock, are you sure the hz selector behind the gauge cluster is selected to 60 hz?
.Guyfang, so at this point I’m assuming that everything is fine with The generator and I can use it in your opinion?
No, you seem to have a problem. Sometimes it works, and sometimes not. You need to figure out why and fix it. Unless you want to run it in Emergency bypass. Something I would not do short of war. When you can start it every time and it works right, its fixed. So, is it doing that?
now the question you probably new l was going to ask, is there anywhere on this sight or one that you can recommend to me that would show the proper way to set this generator up in single phase? Also, is it possible to make it so it wouldn’t be that hard to switch between single and 3 phase?
Zed pointed you in the right direction about single/three phase questions and answers. Thats a good place to start.
And lastly, I saw somewhere that someone had put a remote start or a automatic switchover when power was lost, would you be able to point me in the direction of anything out there if it exists that would be safe and reliable.
SS member KLOPPK has a remote start kit. Read his threads or send him a PM.
thanks again for all your help
That thread zed posted above, tm 9-6115-644-10, adobe reader page 54, or tm pg 0005-4Search for your machine in the Technical Manuals section of the site.
https://www.steelsoldiers.com/showt...eeded-to-work-on-the-MEP-805A-30-KW-Generator
