Needing to haul my M35a2 from Jefferson City to Chattanooga
1,191
You could always plug the oil supply line and remove the turbo and drive it like that.
MRdobb
Chattanooga TN
Well it's not legally ready to be on the road I was in the process of transporting it to where I am staying up here. Do you think with the turbo going out there could potentially be anything else that could have gotten damaged?
bigbird1
Northwest, Indiana
Did you hear any strange engine noise, rattles or bangs? Sometimes the fins break off and enter the intake to the pistons, but not common. The only way to tell is pull the hose off and look at the intake fins.
MRdobb
Chattanooga TN
I am going to pull the turbo tomorrow and see. As the truck was descending down a hill essentially under little load the engine revved wide open and then a pop. After this I drove the truck approx .25 miles to a safe location and it was running with no loud noises. The Turbo was cherry red at this point and caused a flash fire under the hood for a minute causing slight charging to the wires on the starter and generator.
whiskey357
Banned
168
chicago,ill
Ya getting it home is one thing.....drivieng it after a fire ...sizes does not matter is well to be kind......not good for you or the truck.......best of luck getting it home....
