Neutral Safety / reverse switch bushing
NVAM998
90
Virginia
Trying to save money. Found the proper thread pitch for neutral safety and reverse switches on a forum here (can't find the thread now :(. Bought a NSS from the auction site. Sourced a $7 bushing from mc master carr PN 90245A077 which is a 3/4-16 to 9/16-18 threaded insert adapter. Just need to cut it to length with a hacksaw and I should be good to go as soon as I have time to remove the shifter. Bushing fits the switch, hope it fits the shifter.
Hope this helps someone!
Mogman
9,569
Papalote, TX
Are you trying to add reverse lights? if so you will still need the rest of the kit, the entire kit is only about $70
NVAM998
90
Virginia
I was adding a backup camera and monitor and thought it would be nice to control it with the reverse switch instead of manually turning it on/off.
Mogman
9,569
Papalote, TX
Every reverse switch I have added needed these two extra parts besides the switch, lights or camera should be no difference.
NVAM998
90
Virginia
Hi Mogman,
I'm pretty new to all of this. I have a 3 speed M998 and I thought those were only required for the 4 speed or "park" version shifter or something. I could be wrong just like when I thought replacing the incandescent bulbs with LEDs was a simple swap! This forum is extremely useful and I'm trying to give back where I can.
Mogman
9,569
Papalote, TX
You
Hi Mogman,
You could be correct, I have never tried to add a reverse switch to a 3 speed, hopefully someone else will chime in with the info.
