NEW AC installation
Coug
4,842
Olympia/WA
the orientation of the Evap is not that important, as long as the fan can draw air to blow across it. and Make SURE the condensate can drain you don't want a moldy mess in there from standing condensate and or a frozen iced over evap... the drains are in the "Bottom" of the unit.
like the "Universal" Evaporators with the 4 round holes can be mounted vertically with those round holes pointed up and you could marry them to a fabricated cross cab duct like the ones sold for a LOT of money or the "OE" type duct... or you could make one yourself if you are handy... I like mine vertically as the air blows forward more and will blow on aft seat pax... I'd rather have it vertical than taking up what little floor space I already have. Just make sure SURE the Drier is VERTICAL... and in the right flow direction. Most times on the units installed by the Military the Dryer is in the back
Also to add, it isn't uncommon for the filter/dryer to be installed backwards/reverse flow by the military. Everything still works, but it's not really doing it's job properly.
Any time you open up the system you should be replacing the filter/dryer anyway, and they are relatively cheap compared to the rest of the system.
KKroger
232
KC MO
Kept having to explain the direction arrows when installing... and "This Side Up"
KKroger
232
KC MO
New EXACT match blower assembly received and installed so now I have all 3 speeds. Low Mid Hi...
Here are a few pics of the damage due to the broken housing and the place where the squirrel cage burned through the housing.
KKroger
232
KC MO
Kudos to Coldmaster for backing their product. I sent pic of the broken housing the tech asked for a pic of the wiring and immediately shipped out the proper replacement part, UPS Ground so had in hand in exactly 4 days from florida.
KKroger
232
KC MO
Updates, the fuel mileage reduced from 13MPG to 12MPG...
The Temp on an Extreme hot day has increased 10 degrees from 180 to 190... this is with the two wire connector disconnected.
sitting still in traffic does cause the temp to increase a little bit.
