new air petcock and air accessory system
swbradley1
Modertator
1,780
Dayton, OH
If you just need air use the glad hand on the back of the truck. You can get the air hose at any truck stop store.
1,182
well today i decided i hate crawling under my truck to drain the air tanks so i did some thinking.
The center of the new drain valve is about 2 inches further under the truck. I see no gain there.
On most of my trucks, I have added a 2.5" long, 1/2-20 bolt to the drain valve handle. This makes it much easier to rotate.
HASSON1911
24
roseau/mn
actually i don't have to crawl under the truck now today i tap both tanks to one valve that i can reach by just crouching and not getting my a** or back dirty. my truck for some reason doesn't have that valve under the dash someone must have taken it out before i bought it. and i'm pretty happy with this set up probably will buy a cable petcock in the near future but for now she works and holds air for over 24 hours.
HASSON1911
24
roseau/mn
dog there is a gain though the valve it self is farther back the lever is a couple inches farther out. also its bigger and lower than than frame... thus easier to get at. also capital isn't capitalized in capital letters because its an adjective[thumbzup](i thank you for your concern though). plus i wouldn't go to NASA tho to get help anyways seeing as most of them just lost their jobs.
1,182
Let me make this a bit more clear, follow the rules you agreed to when you joined.
• Do not post in all CAPS or in giant run-on sentences without punctuation. Do not post as if texting and do avoid the use of texting abbreviations. We are not the grammar police but we want everyone to easily read your post in at least 8th grade English. It is extra work to post proper sentences from a smartphone but the result will be greatly appreciated. Please do your best to use capitalization, proper spelling and punctuation. It makes it easier for everyone to read!
