New Batteries
JRBAMATEX
Haslet, TX
Is there any reason why I shouldn't replace my 6TL's with normal 1000 Cranking amp Duralast batts? Biggest batts that Autozone had. My 6TL's are done.
Thanks,
dmetalmiki
2,028
London England
well apart from the "looks"...(and (just) WHO looks in the battery case any waze!...with 5 trucks I have ANY and EVERY battery in them! mostly from our local car scrap(breaker) yard!!...obviouslt NO silly lill ones...but any diesel car batts work fine.
bottleworks
Central NC
I have two Walmarts in mine (plus a 3rd for 12VDC). No Issues. It's considered good to get two of the exact type that were manufactured approximately at the same time. 2cents
FSBruva
Marietta, GA
Ditto on the Walmart batteries... Mine have been used for 2 Michigan winters, always started easily no matter how cold, and with relatively short commute times. For $30 bucks apiece, they have earned their keep.
Matt
groundog
wittmann,az
:driver: I use Walmart in my m-35 and group 31 in my m-813A1---but i live in Arizona and dont have to worry about cold weather starts the 6TL run 140.00 ea in Phx.
groundog
wittmann,az
Armada
Buick City, MI
Extreme heat is one of the main killers of batteries too. I remember our (Delco) battery replacements were exceedingly higher in dry, hot regions like the southwest, Saudi, etc. It helps having the batteries located someplace other than in the engine compartment.
NEIOWA
127
NE IOWA
There's a reason the local Exide plant has been running their 6TL line continuously since we deployed to Iraq. And it's not due to cold weather. I'm told there is a HUGE field of old 6TL sitting in Iraq.
Westech
CPL
6,104
207
cow farts, Wisconsin
we replace more batteries in the dead of summer then winter. heat kills more then cold. when its cold it just drops the amps, not that the batt is bad just ends up too weak to start but just let her warm up even with out a charge and shes back. But heat will mess up the inside and boil the heck out of it and dead short the plates.
Westech
CPL
6,104
207
1,129
