tommys2patrick
- 374
- 63
- Livermore, Colorado
I have seen various parts for it on e bay and bought some myself. Leaking brake wheel cylinders is relatively common(at the wheel). rebuild kits available as well as new cylinders. Also master cylinders and the air packs. Hoses that run from the frame mount to the wheels. all pretty available. I have used several of the larger supply houses here in the states but not sure what kind of shipping costs to your location. Like most things the more stuff you bundle in an order at one time may save you overall shipping costs. Usually, there are break points in the weight and size of a shipment when the cost goes up a large amount. So, I would try to get a laundry list of all the parts you want to change, then order them all at once. A number of the vendors that advertise on Steel Soldiers forum have bundle prices for system components like brakes. For example, instead of replacing one brake cylinder buy all 6 and do at the same time. same for brake hoses and brake pads. When one goes bad the rest may not be far behind in going out.awesome to know, yep everything stills on her brake wise, the previous owners told me one brake was leaking., so dunno will know more soon. whos ghe bedt to get rebuild kits from?
I would first download the Technical manuals and parts manuals for your vehicle. They are available free here on Steel Soldiers. That way you can be certain you are ordering the right thing.
