New engine time
rronning84
Eagle River, AK
With the loss of my current engine due to an injector sticking open and melting down the piston, my truck is in the process of getting a new engine. I had it picked up Friday before I left Anchorage and while I am gone it will receive a new power plant.
Triple C
NAPOLEON MO
I didn't know an injector failure would melt a piston. I drove a Freightliner for years and had three or four injector failures (on an N14 motor.) I just limped to a Cummins facility and had it replaced each time. Glad I didn't know it could do that. I assume you were blowing lots of black smoke as your indication. How long did you drive it that way and what fuel were you using? Is this a multifuel? Anybody know if the 250 will do that? Great looking rig by the way.
rronning84
Eagle River, AK
I didn't know at first what was wrong. Just that it was smoking and running crappy. I pulled the valve cover and found a bent push rod. Thinking that was the problem I replaced the pushrod and as soon as I started the truck the new one bent. I knew at this point the piston was hitting the valve so I pulled the head. What I found inside was a piston melted in the sleeve with a hole almost through it. There was a lot of piston material stuck to the head as well. I could easily enough rebuild this engine but because of supply and demand in Alaska a new rebuilt engine is cheaper then a rebuild kit. Also the new engine is supposed to be a 5 ton multi-fuel
