New guy from CT! M923
1,185
pst... use the link in his sigline...
1,185
Perhaps he does need to clarify on this thread, since we are not the clairvoyant ones?
Vintage iron
Falmouth Ma.
Hey, Justin. Nice looking truck! I have a engine for you. I have a Cummins 250 that is in my truck right now or a Cummins 400. Give me a call Matt 617-650-2108.
Kingpepsi
Wallingford CT
Quick question for the Mod of this forum. Is it the norm to merge all of the threads started into a single thread? Or is it just done to clean things up after answers have been posted? Just curious.
1,185
Well, in this case, you had at least 4 threads about the same truck, all running and talking about the same things and 2 in the wrong forums.
I could have taken more time/care and made sure they were merged chronologically, but I didn't.
Kingpepsi
Wallingford CT
So a bit of an update. I pulled an inspection cover on the passenger side of the motor. The #3 liner is completely destroyed. I can see right through the water passage and into the cylinder bore. The con rod appears to be intact however the piston and sleeve are destroyed. There is also a crack in the block at the very bottom of the bore. Looks like its time for a motor.
Suprman
701
Stratford/Connecticut
I am in CT and looking at buying a 5ton. How are you planning to reg it. I was going to try to play dumb and reg it as a camper. I read all the CT statutes there is nothing prohibiting it and no bathroom or sink requirement in the statute.
Will
Kingpepsi
Wallingford CT
I am planning on trying to get it reged as an early american with historic plates. At that point it will be light weight with no commercial usage.
Will
