New Guy from Ohio with 1985 m1008
oilcan
Ohio
Apart from getting her running (mission accomplished thanks to your help), I'm working on figuring out why in the **** 4WD won't engage. I set the hubs, move the selector to 4L (which doesn't completely line up with the indicator on the lever), 4WD lights up on the dash, I get excited, pull into my side-yard and freaking get stuck. Here comes the neighbors Grand Cherokee to the rescue. Grrrrrr.
A symptom that I did notice is, when I went to pull through the mud, she stalled out easier when in 4WD. My father said the wheels weren't spinning up front. I am concerned to say the least. It is currently too wet to crawl underneath and check if the shaft spins and whether or not it is engaging well. Do these CUCVs have something simple I'm overlooking that could be the culprit? Darn.
The locking hubs are probably sticking. Take the hubs apart, then clean and relube everything. Make sure the parts look good, reassemble, and give it a try.
Capt Pat
147
Sandusky, Ohio
Welcome from Sandusky, Ohio, as you're seeing there are a whole lot of very helpful people on this site and you'll also find there are quite a few owners of your type vehicle in Ohio, there are about six in this area alone. Good luck with your projects and you will enjoy the "OD Madness":beer:
