New guy question
smalltruckbigcid
I have a 1009, but from reading some of the posts here about engine swaps a duece has me intrigued. Am I right that a small block chev is almost a bolt in swap? The bellhousing is not a problem? The transfer case is a divorced type, not the style bolted to the back of the transmission. Sorry for the questions but I'm still going through other postings and learning new stuff.
George
Monster Man
If not a bolt-in, it should fit in there with little modification. The t-case is divorced. Just make sure it's built for torque- no tunnel ram manifolds here hehehehe
spicergear
26
Millerstown, PA
Yeah, you can swap it in as damn near a direct bolt in BUT...you'll need to make a couple things work. I bolted a 3053A to a big block and slapped it into a M715 truck. To swap a sbc or bbc into the deuce you'd need the correct bellhousing, flywheel and starter from a medium duty chevy truck, make up the mounts off of it's bellhousing to the deuce's frame, make a front engine mount (no biggy as a lot of older chevys had a mount right under the balancer), and you'd need to figure out clutch linkage which I think would be the biggest deal. Some of the later medium duty's had slave cylinders for the clutch with would save mechancal linkage headaches.
rdixiemiller
Olive Branch Mississipi
You could also build an old 292 Chevy straight six. Those old engines were really torquey, and can be bored to about 315 cubes if I remember correctly. It would be a good fit as far as width is concerned, and would be fun to drive. I had an old C-60 dump, '64 model I think. That old 292 would pull stumps! You would probably take about 1000# off the front axle going that route. I seem to remember 3200 rpm was a good cruising speed for my old dumper.
