spicergear
- 26
- 0
- Millerstown, PA
1974 M35A2. I pulled a perfectly good 478hour turbo multifuel and put in a 225hp,V8 3208/1160 CAT Diesel...636 cubes of grunt. That included new mounts, custom 3.5" SS .100 wall pipes to connect with SS flexpipe to TWO stacks. One is the factory passenger side stack and the other is a pass side factory stack and mirror brackets modified to fit the driver's side in same back of fender/front of cab design. Yes, if friggin' loud with the same amount of muffler the multifuel's had. Heh,heh. I layed a Mack filter housing down on the passenger side fender somewhat like the five tons and plumbed it into the engine bay. The CAT's bell is deeper than the multifuels so I had to make a custom T/O bearing that was 7/8" longer. I also took the factory Multifuel aluminum adapter plate for the SAE bell housings and redrilled it to accept the CAT's one size smaller bell pattern. This all went well and I reloaded the bay with the 1800Lb CAT. That truck was never...ever designed in mind of 'V' style big motor. It barely fit with frame clearance on pass side for exhaust and steering column clearance.
I also had a parts deuce around that I had rescued from a recycler's and it had a T-case with a REB manual shift kit (and from what I understand from Memphis Equipment...a gear correction kit) and a PTO out the back of it. I wanted the choice of when my front axle was pulled in so I swapped out the 'sprag' style case and put this other beauty in. I also rebuilt the E-brake and put on a new cable at the same time.
Recently, I acquired a 20,000Lb Garwood from a 5 ton and put it on the nose. These winches are much larger than the stock 10K Garwoods, and the job had to be...well, somewhat stealthy to fit that bohemoth on the truck and not look stupid. Since I put the CAT V8 in, I've had a decent amount of space from the fan to the fan shroud as the V8 is shorter than the inline 6. I moved the radiator back about 5-6" and slid the big winch back until it's back strap was even with the front of the front crossmember. I added 7-5/8" extension to the frame and got it back together. It's in and looks GREAT!!! The bumper is not turned upside down like with the factory winches as teh 5 tons mount a little differently and slightly lower. I still have to make up the drive. I've got a pile of fresh 5/8" cable and a new clevis end just waiting for it.
I'll paint it at some point...
Here's a pic with 10,100Lbs of Red oak
Pre-winch.
Winch going on.
![](http://img61.exs.cx/img61/3084/deucetruck.jpg)
Pre-winch.
Winch going on.
![](http://img71.exs.cx/img71/369/deucewinch25tk.jpg)
![](http://img71.exs.cx/img71/5926/deucewinch33uo.jpg)
![](http://img71.exs.cx/img71/5459/deucewinch50qb.jpg)
![](http://img71.exs.cx/img71/125/deucewinch67rf.jpg)
![](http://img71.exs.cx/img71/4449/deucewinch82vd.jpg)
![](http://img152.exs.cx/img152/1048/bluewinchstacks9bf.jpg)
