New member from Dallas/Ft. Worth area - New M1123 Owner
20,815
Thank you for accepting me as a new member. New owner of a late 90's M1123, about to undergo a 4 door conversion, paint, and more. Look forward to learning from everyone here and meeting some other locals.
Like all the other guys mentioned - Welcome to the outfit!
There are lots of good folks out there in Texas that have MVs and are willing to point you in the right direction for parts and information. As mentioned, grab a bunch of pictures of your New-To-You vehicle and post them for the rest of us to oogle. You will find the TM's (already mentioned) handy. Incredibly DRY reading but there is a -10 that is the owners manual and a -24 that will help you find part numbers. There are flow charts on how to solve a problem that will point you to a solution faster than just staring at the problem. :)
Again, welcome to the site and congratulations on your new member of the Big Green and Tan family!
tjonesdfw
70
Coppell, Texas
tjonesdfw
70
Coppell, Texas
Initial findings….
Surge on cold start. Voltage gauge bounces back and forth in the green range for several minutes while the engine surges in sync with the gauge moving. Once it warms up, this eventually stops and gauge settles in the green.
Leaking rear diff (I think) at passenger side seal behind the brake rotor. Gets worse after a drive. Fluid is greenish… maybe water intrusion? Pretty decent leak.
Leaking fuel pump, see photos. Pretty wet on the underside of the pump.
Aftermarket Midwest top and x doors from prior years, marked as ‘92. All for sale soon!
Leaking fuel tank at filler neck or sender… no access panel in the tunnel
Holes all over from the MAK upfit in ‘09. Worst are the ragged ones on the top of the bedsides/rear fenders. Any ideas how to cover these up. Didn’t see when I purchased with the troop seats down.
Leak in the Red Dot
Shoulder belts don’t retract
tjonesdfw
70
Coppell, Texas
Thank you! Pics are up finally.
20,815
tjonesdfw
70
Coppell, Texas
Welcome, you'll find lots of great info here, if you haven't downloaded the TM's (manuals) do so you'll learn a lot.
I've found M998 TM's but can't seem to find the A2/M1123 TM's. Probably newbie user error, but could you point me towards the correct TM's by chance? Thank you!
HoveringHMMWV
1,376
AL
