New member from Wales UK , Clutch slipping
mark m35a2
29
13
UK
Hi All , thanks for letting me in , just purchased a M35A2 , in 5th overdrive on full throttle the clutch slips slightly, it will probably last years if I'm careful but just wondering if I remove the propshaft to the transfer box off will the gearbox slide back enough to change the clutch ? thanks in advance Mark
gringeltaube
Staff Member
2,364
Montevideo/Uruguay
Yes. The entire gearbox (with clutch bell housing attached) comes out after just unbolting the jackshaft from the transmission output flange.
Of course, if you remove that shaft entirely it will be even easier.
HDN
4,831
Finger Lakes Region, NY
Thanks guys for the help , at least I know now its not a massive job if needed ... ill check oil level also thanks .. is a Knockle about an inch ? lol
Funny you ask since I actually measured the first knuckle on my index finger to check differential oil level recently :ROFLMAO: At least on my hand it's about an inch.
Welcome to the deuce club :driver:
mark m35a2
29
13
UK
Thanks for the welcome, fuel gauge always reading full now fixed thanks to the club, low air buzzer now fixed thanks to the club and great advice on clutch !
