aheilmann68
- 1
- 18
- North NJ
I have a 002a that is doing the same thing where its not popping the injectors and with the lines to the injectors off, fuel comes out the injector return line. I see this as semi-normal as the injector return line goes to the IP return line. The IP has a fuel galley which is constantly being supplied by the fuel pumps and is at fuel pump pressure, what ever fuel is not compressed and sent to the injectors is returned back to the tank. That return line picks up the injector return line after it goes through an orifice at the tee at the 12 o'clock position on the ip and the unused fuel goes back to the tank. My problem (not to digress from the thread) is that I have the IP flowing fuel but not popping the injectors so either I am not developing pressure or my injectors are incorrectly set. I am having difficulty figuring out how to remove the lug that holds the springs in place. I have removed the cap but all that remains is the threaded portion and I do not want to shred those threads.
